Parallel Coordinate Post Processing
Visualize data trends.
Visualize Data Trends
Visualize all run data across multiple channels on a single plot in the Parallel Coordinate post processing tab.
A parallel coordinate plot is also known as a snake plot.
![](../../images/icons/icon_hamburger_menu.png)
Parallel Coordinate Tab Settings
Settings to configure the parallel coordinate plots displayed in the post processing step.
- Absolute Scale
- Enable an absolute scale versus a relative scale, which is used by default.
- Show min/max
- Turn the display of min and max ranges on and off.
- Show Constraints
- Marks responses with constraint definition.
- Show Best Points
- Accentuate the best optimum run or runs. Dial tolerance value to add alternative optimum runs.
