Calculate the effect using all input variables simultaneously.
            Multivariate effect of an input variable is the difference between the output
                response values when the variable is at its lower and upper values while the
                remaining variables are held constant. All calculations are based on a single linear
                regression model including all variables.
            A system with two variables, X and Y and the output response, F (X,Y).
Table 1. Design Matrix
                                | Run |
                                X |
                                Y |
                                F (X, Y) |
                                | 1 |
                                42.0 |
                                108.0 |
                                1385.4 |
                                | 2 |
                                54.0 |
                                156.0 |
                                2290.2 |
                                | 3 |
                                66.0 |
                                84.0 |
                                3421.2 |
                                | 4 |
                                78.0 |
                                132.0 |
                                4778.3 |
                                | 5 |
                                32.4 |
                                165.6 |
                                824.4 |
                                | 6 |
                                44.4 |
                                93.6 |
                                1548.3 |
             is the reference regression model and
                intercept. A and coefficients, B and C, are calculated using the data set above.
            A = - 2609.8
            B = 88.6
            C = 2.5
            Regression equation:
                    - Effect of X (lower = 32.4, upper = 78.0)
Since we are investigating the
                            effect of X only, Y is held constant. For this example, use the mean
                            value ( = 123.2).
                                - X = 32.4, Y = 123.2
                                - X = 78, Y = 123.2
                    - Effect of Y (lower = 84, upper = 165.6)
                            effect of Y only, X is held constant. For this example, use the mean
                            value ( = 52.8).
                                - X = 52.8, Y = 84
                                - X = 52.8, Y = 165.6
                                | Input Variable |
                                Multivariate Effect |
                                | X |
                                4040.4161 |
                                | Y |
                                202.7087 |
