An Inclusion matrix contains existing data that will be appended into the newly
        created approach as known data points. This data typically comes from other approaches, such
        as DOEs or previously run Optimizations.
            In a DOE, an inclusion can be used to extend
                an existing DOE or concatenate data sets.
                Go to the Specifications tab of the
                        Specifications step.
                In the bottom of the work area, click Add Matrix.
                In the Origin column, select the source of the data.
                            - Approach
                            - Imports data from an approach.
                            - Manual Edit
                            - Manually imports data from an approach, HyperStudy
                                post-processing file (*.data), and external
                                text file.
                            - Text File
                            - Imports data from an external text file. Settings such as location
                                and name are cached in the study file, enabling use in batch
                                mode.
                In the Origin Settings column, select the approach containing run data or
                    browse to the text file.
- Optional:
                If Manual Edit is selected in the Origin column, click
                        Edit in the Display column.
                Review the imported run data.
