The following files are packaged into the
.hstx file:
                    - Study .hstudy file
                    - Resource files
                    - Reference files
                    - .hstdf and .data files
                    - Any other files in study directory
            Tip: Archive is the best method for moving studies.
            If the resource file and reference files are not in the study directory when Export
                Archive is selected, then they will be copied over and included in the
.hstx file. The archived
.hstudy study
                file will be updated to point to the new location of the resource file and reference
                    files.
Note:  Export Archive does not package run folders in approach directories
                    (such as approaches/doe_1/run_xxxx), in order to minimize
                    the archive file size. Files included in resource files that do not reside in
                    the study directory will not be packaged.
