Altair HyperStudy 2022.2 Release Notes
New Features
- Auto-Create a New DOE Approach Based on Pareto Ranking
 - Input variables are ranked based on the percentage of their global contribution. Using the ranking, a new DOE approach can be created with only the most influential ones being active.
 - Visualize Range of Estimates for Each Prediction Point
 - For both Scalar and Vector Fit, an option in Trade-Off has been added to display confidence intervals.
 - Pedigree Information for Each Run
 - The origin of run number and source approach is now reported for each evaluated process.
 - Dedicated Post-Processing Tab for Curve Matching
 - In the Post-Processing step, curve-matching performance for each evaluated point can now be displayed.
 - New Data Source Tool for Extracting Data of Text Files
 - In addition to the ASCII Extract option, Regex Extract tool has been added to extract data via regular expressions.
 - Mobility for Vector Predictions
 - Vector Fit models can now be exported in FMU format.
Enhancements
- Excel Connection: Option to Save as Copy
 - A copy of an excel session can optionally be saved in each run directory.
 - Building Vector Fits with Efficient Sampling
 - Sampling Fit approach has been extended to support vector fit models.
Resolved Issues
- Correction to numerical discrepancies in HS-1610.
 - Undo action now works for removed models.
