Message Log Window
The Message Log window, located at the bottom of HyperStudy, logs warnings and errors encountered while you are conducting your investigation.
Message Log Window Settings
- Setting
 - Action
 - Copy
 - Copy content from the Message Log window, which can then be pasted into another file for your records.
 - Select All
 - Select all of the content in the Message Log window.
 - Clear All
 - Clear all of the content in the Message Log window.
 - Show Timestamps
 - Display the time a message is logged.
 - Show All
 - Display of Warning, Info and Verbose class messages, if any or all of these message types have been disabled.
 - 500 Messages
 - Specify the maximum number of messages to display in the Message Log window at any one time.Note: This feature is useful in limiting the amount of memory the Message Log window uses during the session.
 - Show Warning
 - Enable or disable the display of warning messages.
 - Show Info
 - Enable or disable the display of information messages.
 - Show Verbose
 - Enable or disable the display of verbose messages.
 - Verbose
 - Select the level of detail to log for verbose messages.
 - Log to File
 - Display messages in the Message Log window, and log messages in a separate file.
 - Details
 - Open the log file or change the file path of the log file.
 - Info
 - Display summary information about the current session and message log status.
