abfOpenComponentByIndex()
Opens an existing component in the currently open request.
intabfOpenComponentByIndex(int idx);
- idx
 - The name of the component to be opened.
Return Value
- 0
 - On success
 - 1
 - On failure (indicates component does not exist)
int ret;
ret = abfOpenComponent("X");
if (ret)
	abfNewComponent("X"):
This function must be called after a request has been opened.
Only one component can be open at a time.
Indexes are zero-based.
