AltairIpcGetVectorList
Reads the list of vector data sent to the external program.
int AltairIpcGetVectorList(AltairIpcVectorList *vec_list)
typedef struct
    /*--- Number of vectors in 'vector' list ---*/
    long num_vectors;
    /*--- Number of items in each vector in 'vector' list ---*/
    long *vec_cnt;
    /*--- Vector list, arranged as a pointer list ---*/
    double **vec_val;
} AltairIpcVectorList;
- num_vectors
 - Number of vectors in vector list
 - vec_cnt
 - Array containing number of items in each vector in vector list
 - vec_val
 - Array of pointers to the vectors in the vector list.
AltairIpcGetVectorList returns an integer. If the return value is ALTAIR_IPC_SUCCESS the function succeeded. Otherwise it failed. Check Error Handling for specifics.
