ardi.format
ardi.format.layout
Query layout information. This is valid only for report in Presentation format. Layout information originates from the Ms-office master document.
ardi.format.layout.exists
- Syntax
- Parameters
- -name (mandatory)
 - Value: Name of the layout.
- Returns
 - Boolean
- Example
 ardi.format.layout.exists(name="One Table")
ardi.format.layout.getlist
- Syntax
- Returns
 - The list of layout names.
ardi.format.layout.getmasterlayouts
- Syntax
- Parameters
 - None
- Returns
 - The item ID's of master slide layouts.
ardi.format.layout.getslidelayouts
- Syntax
- Parameters
 - None
- Returns
 - The item ID's of slide layouts example.
