hgtrans control GetStart
Gets the current starting data point index.
HyperGraphTrans Tcl Query
This command gets the index of the first data point to be translated in each channel. The index is one-based and defaults to one (the beginning).
hgtrans control SetStart 10
hgtrans control GetStartErrors
If the starting index is higher than the last data value index present, no data will be translated.
Keywords
get start
