Hotspot Finder API Structure
Hotspot Finder APIs
- Using the hotspot search, you can find hotspots in a model based on filtering rules and a logical combination of such rules.
 - Data filtering rules for Selection set, ignoring specific element types, threshold values, maintaining a minimum distance between hotspots and limiting the search to a number of extreme top or bottom values.
 - The rules can be used in sequence using a keyword THEN and also you can get a combined effect using boolean logic based on AND, OR and brackets.
 - These APIs will work in v2020 and all future releases.
Figure 3. Recommended approach
Hot Spot Best View
Hotspot Best View Modes - Global Views
Global views provide you with a perspective of the all the hotspots in the reference of entire model, in an isometric view.
You can chose to automatically hide unwanted components from global views.
- Global View
 - Shows all of the hotspots.
- Default
 - Shows the entire model and all hotspots.
Figure 5. - Region
 - Shows only the attached elements around all hotspots, rest of the model is
                      transparent.
Figure 6. - Spheres
 - Shows only a spherical region around all hotspots, rest of the model is transparent.
 - Component
 - Shows only the components with the hotspots, rest of the model is
                      transparent.
Figure 7.
 - Global Location
 - Shows only one hotspot with entire model visible.
Figure 8.
Hotspot Best View Modes - Component Based Views
- Component Transparency
 - Shows only one hotspot with its component and contour plot, the rest of the model is
                transparent.
Figure 9. - Isolate Component
 - Shows only one hotspot with its component isolated, the rest of the model is
                hidden.
Figure 10.
Hotspot Best View Modes - Local Views
Local views help a you gain extra insight on a particular hotspot and the region around it.
- Entity Zoom
 - The hotspot is shown with its component isolated and zoomed in 3X.
Figure 11. - Transparency
 - Only the region (spherical) around the hotspot is shown, everything else in the
Figure 12. - Contour
 - The hotspot is shown with the entire model contoured and zoomed into the
                hotspot.
Figure 13.
Hotspot APIs
- Advanced Query
- poIPost
 - poIPost AddAdvancedQuery
 - poIAdvancedQuery
 - poIAdvancedQuery AddSimulations
 - Hotspot Rules
- poIQueryRule
 - poIQueryRule GetID
 - poIQuerySetRule
 - poIQuerySetRule GetSelectionSet
 - poIQueryIgnoreElemTypeRule
 - poIQueryIgnoreElemTypeRule GetElementTypeList
 - poIQueryExpressionRule
 - poIQueryExpressionRule GetExpression
 - poIQueryDistanceRule
 - poIQueryDistanceRule GetDistance
 - poIQueryExtremeRule
 - poIQueryExtremeRule GetExtreme
Best View APIs
- Use Hotspot Search Results
 - poIAdvancedQuery CreateBestViews
 - Use Individual Entities for Best View
 - GetEntity
 - Display Settings
 - GetFocusRegionSize
 - Note Settings
 - GetNoteDistance
 - Show Hotspot
 - ActivateView
