hwIAVIExportOptions GetFrameRate
Gets the frame rate used when exporting AVI files.
hwIAVIExportOptions_handle GetFrameRate
HyperWorks Tcl Query
This parameter is used when exporting AVI files from either the video or animation clients during HTML export.
Files that do not support subcases will return Success, but the list argument will be empty.
mySessionName GetAVIExportOptionsHandle myAviOptions
myAviOptions GetFrameRateError
If an error occurs, this command returns 0.
