hwIDataFile GetComponentLabel
Returns a string indicating the request’s label.
hwIDataFile_handle GetComponentLabel
HyperWorks Tcl Query
None.
View new features for HyperWorks Desktop 2022.2.
Gets the label of an item of meta data associated with a file channel.
Gets a list of meta data items associated with a file channel.
Gets the type of an item of meta data associated with a file channel.
Gets an item of meta data associated with a channel of a file.
Finds the data values in a specific channel.
Returns a list of all components for a given data type.
Returns a list of all datatypes.
Returns a string indicating the filename.
Returns a list of all components for a given data type and request.
Finds the hash value (sum of the structure of the file).
Returns a list of all requests for a given datatype.
Returns the name of the current subcase.
Returns a list of the IDs of all subcases.
Returns a list of all subcases.
Gets the component name of the time channel associated with a specified data channel.
Gets the datatype name of the time channel associated with a specified data channel.
Gets request name of the time channel associated with a specified data channel.
Gets the marked state of the given data channel.
Finds whether the data file handle holds a file that exists.
Finds whether the data file handle holds a valid file.
Marks the given data channel.
Reads the marked data channels.
Sets the current file in the data file handle.
Sets the current subcase.
Unmarks all data channels.
Unmarks the given data channel.
None.
