hwIH3DExportOptions SetCompressOutput
Sets whether to apply compression to results during output.
hwIH3DExportOptions_handle SetCompressOutput flag
HyperWorks Tcl Query
Compression is comprised by two processes: lossy and non-lossy. To produce lossless compression, turn compression on and set the allowable error to zero.
This command is related to the H3D option on the Publish Session dialog.
- flag
- True or false.
mySessionName GetH3DExportOptionsHandle option_handle
option_handle SetCompressOutput trueErrors
None.
