mdlIModel GetAnalysisList
Gets the list of all the available analysis variable names.
mdlIModel_handle GetAnalysisList
MotionView Tcl Query
This command retrieves a list of all the available analysis variable names. The MDL statements will vary per the entity's parameter requirements.
hwi OpenStack
mySessionName GetProjectHandle myProjectName
set activePageNum [myProjectName GetActivePage]
myProjectName GetPageHandle myPageName $activePageNum
set activeWinNum [myPageName GetActiveWindow]
myPageName GetWindowHandle myWindowName $activeWinNum
myWindowName GetClientHandle myClientName
myClientName GetModelHandle myModelName
myModelName GetAnalysisList
myModelName ReleaseHandle
myClientName ReleaseHandle
myWindowName ReleaseHandle
myPageName ReleaseHandle
myProjectName ReleaseHandle
mySessionName ReleaseHandle
hwi CloseStackErrors
None.
