mdlIModelClient SetOutlineGraphicWidth
Sets the outline graphic width.
mdlIModelClient_Handle SetOutlineGraphicWidth width
MotionView Tcl Modify
This command sets the outline graphic width.
- width
- The value to which the width of the outline of the graphic is to be set.
Copy the file slider_crank.mdl into the present working directory.
hwi OpenStack
hwi GetSessionHandle sess1
sess1 GetProjectHandle pro1
pro1 GetPageHandle pa1 [pro1 GetActivePage]
pa1 GetWindowHandle win1 [pa1 GetActiveWindow]
win1 GetClientHandle mcl
mcl SetOutlineGraphicLineWidth 5
mcl ReleaseHandle;
win1 ReleaseHandle;
pa1 ReleaseHandle;
pro1 ReleaseHandle;
sess1 ReleaseHandle;
hwi CloseStack;Errors
Returns 0 if successful.
