plt3DIChart GetHighlighted
Returns the chart’s highlight state.
plt3DIChart_handle GetHighlighted
HyperWorks Tcl Query
- True
- Chart is visible.
- False
- Chart is not visible.
None.
View new features for HyperWorks Desktop 2022.2.
Gets a handle to a pltIVector interface for the specified curve.
Gets the number of points on the chart.
Returns the chart’s shadow color index.
Gets the shadow plane of the chart.
Returns the shadow’s visibility state.
Gets the symbol style of the chart.
Gets the chart’s visibility state.
Sets the chart’s highlight state.
Sets the chart’s shadow color index.
Sets the shadow plane of the chart.
Sets the auto shadow visibility state.
Sets the symbol style of the chart.
Sets the auto chart visibility state.
None.
