plt3DICurve GetParametric
Gets whether a curves X, Y, and Z vectors are parameterized by a U vector.
plt3DICurve_handle GetParametric
HyperWorks Tcl Query
This is the least number of points in any of the curve's data vectors. Returns the number of points on the curve.
Parametric curves contain a hidden vector, U, which can be used to parameterize X, Y, and Z. If this flag is set, U will be evaluated before X, Y, and Z.
mySessionName GetProjectHandle myProjectName
myProjectName GetPageHandle myPageName 1
myPageName GetWindowHandle myWinName 1
myWinName GetClientHandle myClientName
myClientName GetCurveGroupHandle myGroupName 1
myGroupName GetCurveHandle myCurveName 1
myCurveName GetParametricErrors
None.
