plt3DIPlane GetHighlighted
Gets whether a plane is highlighted.
Gets whether a plane is highlighted. GetHighlighted
HyperWorks Tcl Query
The appearance of a highlighted plane will change to indicate that it is active or has been picked through the GUI. To see this effect, alter the highlighted flag to cause a redraw of the client. Returns true or false.
mySessionName GetProjectHandle myProjectName
myProjectName GetPageHandle myPageName 1
myPageName GetWindowHandle myWinName 1
myWinName GetClientHandle myClientName
myClientName GetPlaneHandle myPlaneName
myPlaneName GetHighlightedErrors
None.
