HyperStudy allows you to perform Design of Experiments (DOE), optimization, and stochastic studies in a CAE environment. It
allows you to study the different aspects of a design under various conditions, including non-linear behaviors. It
can be applied in the multi-disciplinary optimization of a design combining different analysis types.
After you've created design variables, click Next to go
to the Specifications page.
The Specifications page provides two modes of evaluating the set up:
Nominal Run – runs one simulation where all of
the design variables values are set to the initial values.
System Bounds Check – creates three runs by
default; one where all the design variables are at their lower bounds,
one at the nominal values, and one at their upper bounds.
Select the desired mode and click Apply.
Note: If System Bounds Check is selected, the number of runs can be modified by
clicking the Modify Run Matrix button (in order to make changes in the Run Matrix
dialog).
Click Next to go to the Evaluate page.
The Tasks tab lists the run as StepIndex and updates the status of writing the
solver file, executing it, and extracting the results.
Note: Make sure that the Write,
Execute, and Extract check
boxes are activated (in the Settings pane on the right).
Click Evaluate.
Further steps are common in HyperStudy for all applications. Refer to the HyperStudy Online
Help for additional information.
