The MotionView Tools menu allows you to check a model for errors, select a writer and user mode, and access such panels as Reports,
Templex Functions, and Options.
A metadata file is automatically generated when you save the active MDL model as an ADAMS or MotionSolve deck or you
run a solver analysis on the active model.
Implicit graphics can be displayed for all applicable entities, allowing you to
visualize their location and orientation.
Visualization helps you control which implicit graphics
are active, as well as size entities and select whether the entity is sized relative to
the model or relative to the screen. You can also control the color of each entity.
Entities containing implicit graphics include:
Points
Bodies
NLFE Bodies
Markers
Joints
Advanced Joints
Couplers
Bushings
Spring Dampers
Beams
PolyBeams
Forces
Motions
Deformable Curves
Deformable Surfaces
Contacts
From the Model menu, click Implicit Graphics.
The Implicit Graphics Settings dialog is displayed.
Figure 1. Implicit Graphics Settings Dialog
Activate the check boxes in the Visible column for the implicit graphics that
you want to display.
Activate the check boxes in the Zoom column for the implicit graphics that you
want to change size in a zoom, .
Enter a value in the Size text box to change the size of a specific implicit
graphic.
Click on a color box for the implicit graphic that you want to change
color.
Click Close to close the Implicit Graphics Settings
dialog.
