Saving Model Files
From the File menu select Save > Model.
Or
Click the Save Model button on the Standard toolbar.
Note: If the model in the data base is a new model, a dialog will be displayed. However if the model already has a file name, it will be saved directly (no dialog will be displayed). -
From the Save As Model dialog, specify a file name and
click Save.
The model is saved.
