OptiStruct is a proven, modern structural solver with comprehensive, accurate and scalable solutions for linear and nonlinear
analyses across statics and dynamics, vibrations, acoustics, fatigue, heat transfer, and multiphysics disciplines.
The OptiStruct Example Guide is a collection of solved examples for various solution sequences and optimization types and provides
you with examples of the real-world applications and capabilities of OptiStruct.
This section presents nonlinear small displacement analysis examples generated using OptiStruct. Each example uses a problem description, execution procedures, and results to demonstrate how OptiStruct is used.
This section presents nonlinear large displacement analysis examples generated using OptiStruct. Each example uses a problem description, execution procedures, and results to demonstrate how OptiStruct is used.
A uniform, homogeneous plate which is symmetric about horizontal axes in both geometry and loading, to find the maximum
axial stress in the plate with a hole.
Snap-fit is a combination of two components namely mating and base part which form a mechanical attachment between them
by means of locators, locks and enhancements. Nonlinear Static Analysis with large displacement theory is used to solve
this example.
Contact smoothing is useful to increase accuracy of the contact solution. An enforced displacement to push two concentric
rings toward each other to engage the contact is used. The usage of NLOUT entry allows you to study the progression of SPC force over successive increments.
Demonstrate a revolute joint using JOINTG and MOTNJG. The JOINTG entry can be used for defining a variety of joints, including revolute, ball, universal, cardan, and so on. Motion on
these joints can be applied using the MOTNJG entry.
The PCOMPLS entry can be used to define continuum shell composites using solid elements. Currently first order CHEXA and CPENTA solid elements are supported.
Demonstrates self-contact which is used in this nonlinear large displacement implicit analysis involving hyperelastic
material and contacts using OptiStruct.
This section presents nonlinear transient analysis examples generated using OptiStruct. Each example uses a problem description, execution procedures, and results to demonstrate how OptiStruct is used.
This section presents normal modes analysis examples generated using OptiStruct. Each example uses a problem description, execution procedures, and results to demonstrate how OptiStruct is used.
This section presents complex eigenvalue analysis examples generated using OptiStruct. Each example uses a problem description, execution procedures, and results to demonstrate how OptiStruct is used.
This section presents thermal and heat transfer analysis examples generated using OptiStruct. Each example uses a problem description, execution procedures, and results to demonstrate how OptiStruct is used.
This section presents analysis technique examples generated using OptiStruct. Each example uses a problem description, execution procedures, and results to demonstrate how OptiStruct is used.
This section presents shape optimization example problems, solved using OptiStruct. Each example uses a problem description, execution procedures and results to demonstrate how OptiStruct is used in shape optimization.
The examples in this section demonstrate how topography optimization generates both bead reinforcements in stamped
plate structures and rib reinforcements for solid structures.
The examples in this section demonstrate how the Equivalent Static Load Method (ESLM) can be used for the optimization
of flexible bodies in multibody systems.
This section presents multiphysic examples generated using OptiStruct. Each example uses a problem description, execution procedures, and results to demonstrate how OptiStruct is used.
This section presents response spectrum examples generated using OptiStruct. Each example uses a problem description, execution procedures, and results to demonstrate how OptiStruct is used.
This section presents nonlinear explicit analysis examples generated using OptiStruct. Each example uses a problem description, execution procedures, and results to demonstrate how OptiStruct is used.
This section presents piezoelectric analysis examples generated using OptiStruct. Each example uses a problem description, execution procedures, and results to demonstrate how OptiStruct is used.
OS-E: 0165 Contact Smoothing With Two Concentric Rings
displacement to push two concentric rings toward each other to engage the contact is used. The
Figure 1. FE Model
Model Files
Before you begin, copy the file(s) used in this example to
your working directory.
Conduct a Large Displacement Nonlinear Analysis solution with contact smoothing. Enforced
displacement is applied on the center of the RBE2 and the inner ring is
pushed on to the outer ring. The outer surface of the outer ring is constrained in
translation (Figure 1).
FE Model
Elements Types
CHEXA
CPENTA
The linear material properties are:
MAT1
Young’s Modulus
2.1E+5
Poisson's Ratio
0.3
Large Displacement Nonlinear Static Analysis
NLSTAT
LGDISP
Nonlinear Parameters
NLPARM
NLOUT
NLADAPT
Results
The SPCFORCE results are shown in Figure 2(a)
Smoothing is Active; (b) Smoothing is Inactive, for both cases, with and without smoothing.
Note: The activation of contact smoothing improves the SPC Force results.
SPC force output plot shows a smoother curve with contact smoothing turned On. Figure 2. (a) Smoothing is Active; (b) Smoothing is Inactive
