OptiStruct is a proven, modern structural solver with comprehensive, accurate and scalable solutions for linear and nonlinear
analyses across statics and dynamics, vibrations, acoustics, fatigue, heat transfer, and multiphysics disciplines.
The OptiStruct Example Guide is a collection of solved examples for various solution sequences and optimization types and provides
you with examples of the real-world applications and capabilities of OptiStruct.
This section presents nonlinear small displacement analysis examples generated using OptiStruct. Each example uses a problem description, execution procedures, and results to demonstrate how OptiStruct is used.
This section presents nonlinear large displacement analysis examples generated using OptiStruct. Each example uses a problem description, execution procedures, and results to demonstrate how OptiStruct is used.
This section presents nonlinear transient analysis examples generated using OptiStruct. Each example uses a problem description, execution procedures, and results to demonstrate how OptiStruct is used.
This section presents normal modes analysis examples generated using OptiStruct. Each example uses a problem description, execution procedures, and results to demonstrate how OptiStruct is used.
This section presents complex eigenvalue analysis examples generated using OptiStruct. Each example uses a problem description, execution procedures, and results to demonstrate how OptiStruct is used.
This section presents thermal and heat transfer analysis examples generated using OptiStruct. Each example uses a problem description, execution procedures, and results to demonstrate how OptiStruct is used.
Heat sink with fins are commonly used in engineering applications to dissipate heat. The 3D geometry of an aluminum heat
sink designed for cooling. The cross-sectional view of a furnace constructed from two materials.
Nonlinear transient heat transfer analysis of a manifold is done using OptiStruct. The thermal conductivity of the material is a function of temperature.
This section presents analysis technique examples generated using OptiStruct. Each example uses a problem description, execution procedures, and results to demonstrate how OptiStruct is used.
This section presents shape optimization example problems, solved using OptiStruct. Each example uses a problem description, execution procedures and results to demonstrate how OptiStruct is used in shape optimization.
The examples in this section demonstrate how topography optimization generates both bead reinforcements in stamped
plate structures and rib reinforcements for solid structures.
The examples in this section demonstrate how the Equivalent Static Load Method (ESLM) can be used for the optimization
of flexible bodies in multibody systems.
This section presents multiphysic examples generated using OptiStruct. Each example uses a problem description, execution procedures, and results to demonstrate how OptiStruct is used.
This section presents response spectrum examples generated using OptiStruct. Each example uses a problem description, execution procedures, and results to demonstrate how OptiStruct is used.
This section presents nonlinear explicit analysis examples generated using OptiStruct. Each example uses a problem description, execution procedures, and results to demonstrate how OptiStruct is used.
This section presents piezoelectric analysis examples generated using OptiStruct. Each example uses a problem description, execution procedures, and results to demonstrate how OptiStruct is used.
An engine exhaust manifold with conjugate heat transfer and structural deformation,
constructed of gray cast iron, initially at 300 K. The manifold outer surface has a
convective heat transfer coefficient of h = 6 W/m2 K at 300 K. The four inlets to the
manifold are held at 500 K with air as the fluid at 5 m/s.
Temperature history is available after linear transient heat transfer analysis. In order to
apply temperatures at multiple time steps to a structural analysis, one step transient
thermal stress analysis should be used. It provides displacement and stress history for the
duration of transient heat transfer.
In order to perform one step transient thermal stress analysis, you can define a linear
transient heat transfer subcase and a static subcase. TEMPERATURE case
control cards with HTIME keyword can be used in static subcase to choose
selected or all time steps to perform stress analysis.
Tip: One step transient
thermal stress analysis is to perform static analysis at all output time steps of
transient heat transfer analysis. Transient heat transfer analysis outputs temperature
results for every time step by default. This can result in a long simulation time and
create large result files. It is recommended to use the skip factor on
TSTEP card to write temperature results for a limited number of time
steps, with which one step transient thermal stress analysis can still capture the stress
history without added computational cost. When one step transient thermal stress analysis
is a nonlinear static subcase, the number of time steps should be further limited.
DLOAD is not supported.
FE Model
Element Types
CTETRA
The linear material properties are:
Property
Value
Young’s Modulus
1.38E11 PA
Poisson's Ratio
0.283
Initial Density
7817 Kg/m3
Stress versus Strain curve defined for MATS1 (for NLSTAT analysis
only).
Results
From OSTTS (One Step Thermal Transient Stress) results, you can see the thermal results
from the subcase 1 (Thermal Transient) as in Figure 2 and the Stress
results from subcase 2 (NLSTAT) as in Figure 3. Figure 2. Grid Temperature Contour from Subcase 1 Figure 3. Element Stress and Plastic Strain form Subcase 2 Figure 4. Stress and Temperature versus Time (Stress scaled to 1e-6)
