Altair Inspire User Guide
2022.2
  1. Home
  2. Print 3D
    Prepare and run an additive manufacturing simulation, and export a file for 3D printing.
  3. Selective Laser Melting (SLM)
    Use the Selective Laser Melting process for additive manufacturing.
  4. Print Part (SLM)
    Select parts to print and assign materials for selective laser melting.
  • What's New
  • Get Started
  • Tutorials
  • Upcoming Features
  • Parametric Modeling
  • Structures
  • Motion
  • Design Explorer
  • Manufacture
  • Print 3D
  • Inspire Python API
  • Reference
  • Keyboard Shortcuts and Mouse Controls
Index
2022.2
  • What's New
    Discover new features and enhancements.
  • Get Started
    New to Inspire? Learn the basics here.
  • Tutorials
    Start using Inspire with our interactive tutorials.
  • Upcoming Features
    Explore features in development that have not yet been officially released.
    Create parametric sketches, geometry, and PolyNURBS with construction history and variables.
  • Structures
    Set up your model and run a structural analysis or optimization.
  • Motion
    Set up and run a motion analysis, plot the results, and export the results.
  • Design Explorer
    Evaluate designs by using geometric variables and applying a design-of-experiments (DOE) or optimization method.
  • Manufacture
    Set up and run a basic porosity or thinning analysis.
  • Print 3D
    • Selective Laser Melting (SLM)
      • Print Part (SLM)
      • Printer
        Configure the 3D printing bed. You can select a default printer or choose from several standard printers.
      • Orientation (SLM)
        Orient the part in relation to the printing bed.
      • Support
        Create and partition supports required for 3D printing.
      • Slice
        Examine the part in layers to validate its geometry before 3D printing.
      • Export
        Export a file containing the prepared part and/or supports for 3D printing.
      • Calibration
        Print a small part (also called a coupon) to measure the deformation of the material after printing, and use this data to calibrate the print analysis.
      • Analyze (SLM)
        Run a additive manufacturing analysis, then view and plot the results.
    • Binder Sinter
      Use the Binder-Sinter process for additive manufacturing.
    Learn how to access the Inspire Python API including online help, quick start demos, and the Extension Manager.
  • Reference
    View the glossary, frequently asked questions, and errors and alerts.
    Learn keyboard shortcuts and mouse controls for common operations.
2022.2
  1. Home
  2. Print 3D
  4. Print Part (SLM)
  • What's New
  • Get Started
  • Tutorials
  • Upcoming Features
  • Structures
  • Motion
  • Design Explorer
  • Manufacture
  • Print 3D
  • Reference
Index
Print Part (SLM)
Start with an optimized part in Inspire, or open a CAD file (preferably .stmod or Parasolid) with a part you'd like to prepare for 3D printing.
  1. Select the Print Part tool on the Print3D ribbon.
  2. Select one or more parts in the modeling window to prepare it for 3D printing.
  3. Assign a material to the part in the microdialog.
  4. Right-click and mouse through the check mark to exit, or double-right-click.
Note:
  • You can view the Materials Database and create your own materials by clicking the icon on the microdialog.
  • When using the Print 3D module, materials should only be assigned or changed using the Print Part tool. Assigning a material using the part context menu or the Property Editor will instead assign an Inspire structural material, which should be ignored.
  • If you select multiple parts to print, you then define the orientation and apply supports for each print part individually. When you run the simulation, the analysis will consider all the parts jointly in its calculations.
Designate Parts as Supports
Designate existing parts as supports.
  1. Select the Designate Supports tool on the Print Part icon.
  2. Select parts to designate them as supports.
