Coil Springs
Use the Add/Edit Coil Springs tool to apply a translational spring-damper force along the line of sight between two parts.
![](../../../images/icons/inspire/icon_springs.png)
Click the satellite icon that appears when you hover over the Springs icon to view
a list of all coil springs or torsion springs in your model.
Position the endpoints of the coil spring, then define the preload force, stiffness, and damping rates.
- The default spring has no preload. As you drag the endpoints, the installed length (Li) changes dynamically, which also changes the preload value.
- If you want a damper rather than a spring, change the spring Type in the microdialog and select Damper.
- Color attributes for the spring can be set using the Property Editor.
- Use the Section Cut tool to place a spring inside two parts.
- Suppress/Unsuppress a coil spring to understand its effect on your model. On the spring, right-click and select Suppress. From the Model Browser or Table, right-click and select Unsuppress.
Nonlinear Spring Dampers
Nonlinear stiffness and damping characteristics can be entered for spring dampers for motion analysis.
- Sometimes it is easier to remove the left side data, work on the right side data, and then use the Reflect to Left Side button to reflect your data.
- Clicking the Replace with Linear Equivalent button will use the Stiffness value (shown greyed out on the microdialog) and display it as an editable curve in the graphical area of the Profile Editor.
- The Derivative button in the legend is helpful for the Akima and Cubic interpolation methods because it helps you visualize discontinuities in your data. Introducing more points may help you smooth the profile.
- The Provide Signals to Plant option is available for spring dampers in motion, but is disabled by default. It can be found in the Property Editor and when enabled, the motion Export operation will include the necessary plant signals in the .mdl file for use in MotionView, MotionSolve, and Altair Activate.
- See the Profile Editor for an explanation of the buttons and visualization options.
Move the Endpoints of a Coil Spring
When editing a coil spring you can reposition the endpoints or move them away from the part.
Spring Options
Double-click the spring to edit the spring's endpoints, diameter, and preload force.
![](../../../images/figures/inspire/coil_springs_manipulators.png)
Figure 2. Coil Spring Manipulator
- Endpoints
- Click-and-drag the endpoint manipulators to reposition the spring. You can move endpoints along a part, and it will snap to snap points, edges, and faces. You can also use the manipulator to drag an endpoint to a different part.
- Spring Diameter
- Click-and-drag the white arrow manipulator to change the diameter of the spring, or enter a
value in the microdialog. Click the chevron
to see additional options.
- Diameter: Change the diameter of the coils. Click the
icon to restore the default dimensions of the coil spring.
- Coils: Change the number of coils in the spring.
- Wire Diameter: Change the diameter of the wire.
- Preload Force
- Click the red arrow to change the direction of the preload force. This indicates whether the spring would expand or contract to reach its free length.
Microdialog Options
Double-click the spring and use the options in the primary microdialog to edit it.
Click the to view advanced
options.
![](../../../images/figures/inspire/coil_springs_microdialog.png)
Figure 3. Coil Springs Microdialog
- Type
- The default type is spring damper. You can also select just the spring, or just the damper. It is advisable to include some damping.
- Set Stiffness
- Enter a positive value for the stiffness rate of the spring. (To have no stiffness, set the spring Type to Damper.)
- Set Damping
- Enter a positive value for the damping rate of the spring.
- Preload Mode
- Click the Fi button to have Inspire automatically calculate the free length when you change the preload value or reposition the endpoints.
- Reverse Preload
- Reverse the direction of the preload force in the spring. A positive force pushes; a negative force pulls.
- Set Preload
- Enter a magnitude for the preload force in the spring. Click the
icon to reset the preload to zero.
- Free Length Mode
- Click the Lf button to have Inspire automatically calculate the preload when you change the free length value or reposition the endpoints.
- Set Free Length (Lf)
- The free length is the length of the spring in its resting state. If you enter a preload force, the free length is automatically calculated from the stiffness.
- Installed Length (Li)
- The installed length is the distance between the endpoint manipulators, or the length of the spring as installed. Cannot be edited directly, but you can change the value by repositioning the endpoint manipulators.
- Move Spring Endpoints
- Opens the Move tool to reposition the spring's endpoints.
- Flip to the Other Side
- Use to flip/invert the spring damper.
Coil Spring Properties
Refine the behavior and appearance of coil springs using the properties available in the Property Editor (F3).
- Damper Scale
- Use to increase the damper diameter relative to the spring diameter. The value must be greater than 0, or less than or equal to 1. The default 0.5.
- Spring Limits
- Spring limits are applied by default, and prevent the spring from expanding or collapsing beyond its natural limits.
Springs Table
The Springs table lists all of the coil and torsion springs in your model and allows you to edit various attributes. Click the Coil tab to view coil springs.
![](../../../images/figures/inspire/coil_springs_table.png)
Figure 4. Springs Table
To | Do this |
Rename a spring | Select the cell in the table and then click again to make the field editable. |
Change a value | Select the cell in the table and then click again to make the field editable. Some fields are for display only. |
Sort a column | Click the column header. Click repeatedly to toggle between ascending and descending order. |
Add or remove columns | Right-click on a column header. |
Shortcuts
To | Do this |
Deselect a feature | Hold down the Ctrl key and left-click a selected (red) feature. |
Exit the tool | Right-click and mouse through the check mark to exit, or double-right-click. |
