Review Flexible Body Modes
Review and animate flexible body modes using the Analysis Explorer.
Select the Review Flexible Body Modes tool.
- Select a flexible part to review the flexible body modes. (Flexible parts are shown in blue.)
- Select a Flexible Body Mode in the Analysis Explorer to view the displacement.
Click the
button on the Animation Toolbar to review the motion analysis.
- See Review Flexible Body Results for information on how to view local deformations, stress and strain.
Animation Toolbar
Use the animation toolbar to play, record, and configure the animation.
Figure 1. Animation Toolbar
- Animation Settings
- Click to open the Animation Settings.
- Play and Record/Stop Recording
- Click the button to begin recording the results; the icon changes to red to indicate that it is recording. Click the icon again to stop recording.
- Start Animation/Pause Animation
- Click the button to start or pause the animation. Use the arrow buttons to jump the first or last frame in the animation.
- Move to First/Previous/Next/Last Step
- These buttons allow you to step through the animation frame-by-frame. If you hold down the Previous or Next button, it will auto-repeat. If you want to skip frames, use the Increment By feature in the Animation Settings; hold Ctrl to temporarily override this behavior.
- Slider
- Drag the slider on the toolbar to view a particular point during the analysis; use the arrow keys to move frame-by-frame through the animation.
- Current Step
- Displays the current time or frame. You can also enter a value to go to the nearest time/frame.
- Connection Results (structures only)
- Click to extract reaction forces at fasteners. This option is only avaiable for structural analysis.
- Make Current Frame the New Design Position (motion analysis only)
- Click to use the current position of the mechanism as the model's starting point for the next run. This option is only avaiable for motion analysis.
- Plot Manager (motion analysis only)
- Open the Plot Manager to browse and plot motion results data, create cross plots (data vs. data), define pages in different layouts, and save the plots you've defined as a template for reuse. This option is only avaiable for motion analysis.
- Display Linear Modes Table (motion linear analysis only)
- Open the Linear Modes table to view the results of a linear analysis in complex number form with natural frequencies and damping ratio. This option is only avaiable for linear motion analysis.
Show Options
Determine what is made visible in the modeling window when viewing analysis results. You can show or hide the initial shape, loads and supports, deformation, and/or contours.
Option | Description | Note | |
Show/Hide Initial Shape | ![]() |
Show/hide the initial shape as a reference. | |
Show/Hide All Loads and Supports | ![]() |
Show/hide loads and supports. You can also show only the current loads and supports. | |
Show/Hide Deformed State | ![]() |
Show/hide the deformed shape as a reference. | |
Show/Hide Contours | ![]() |
Show/hide contours. | |
Options | ![]() |
Show/Hide Elements | ![]() ![]() |
Show/hide the element edges. | This icon appears under the view controls in the lower left of the modeling window, but only when the Analysis Explorer is active. |
