Use the Analysis Explorer to view buckling modes results. Buckling modes are only
        available when running an OptiStruct analysis.
        Run an analysis with buckling modes selected.
                On the Structures ribbon, select the Show Analysis
                        Results tool on the Analyze icon.
                Select the run you want to view in the Analysis Explorer.
                Select one of the (Buckling) load cases.
                Select a Buckling Load Factor. The displacement for the
                    selected mode is displayed on the modeling window. If the value for that mode is
                    displayed in the modeling window. If the value for that mode is between 1 and 0,
                    the part is predicted to buckle. If the value is between 0 and -1, it will
                    buckle in the opposite direction.
                Right-click or press Esc to close the
                        Analysis Explorer and return to the original
                    part.
                    Tip:
                            - To change the upper or lower bound for the results slider, click on
                                the bound and enter a new value.
                            - To filter the results so that areas on the model with displacement
                                greater than a specified value are masked, click and drag the arrow
                                on the results slider.
