Generate multiple sketches to create a parametric bracket with recessed areas using the Offset, Push/Pull, and Boolean
tools, and using a construction line as a reference. You will also assign dimensions and create variables.
Learn how to use constraints and construction geometry to create more sophisticated sketches. In this example, you'll
build a tapering arm for a clamp around a reference centerline, paramaterizing the sketch in terms of the construction
lines.
Learn how to find and remove pockets, holes, rounds, and fillets.
In this lesson you will learn how to:
Find and remove pockets and holes
Find and remove rounds and fillets
Push and pull faces
The Simplify tools on the Geometry ribbon can be used to remove features that normally
prevent easy modification of a design space used for optimization. This tutorial will
illustrate how to modify your design space by removing pockets, rounds, and fillets.
Open the Geometry Simplification Model
Press F7 to open the Demo Browser.
Double-click the Geometry Simplification.x_t file to load
it in the modeling window.
Adjust the view so the model is positioned as shown below:
Make sure the display units in the Unit System Selector are set to
MPA (mm t N s).
Remove Holes and Pockets
Select the Simplify tool on the Geometry ribbon.
Select the Holes tool from the secondary ribbon.
Inspire automatically finds all of the holes and
pockets in your model, which are shown in red. The number shown above the Holes
icon indicates the total number of holes and pockets found, in this case
twelve.
Mouse over one of the pockets.
You'll notice the mouse cursor changes and shows a check
mark.
Left-click the pocket to remove it.
Continue removing the other five pockets (there are three on each side) by
left-clicking on them.
Note: Do not remove the holes.
Right-click and mouse through the check mark to exit, or double-right-click.
Find Rounds and Fillets
Select the Rounds tool from the secondary ribbon.
Inspire automatically finds all of the rounds and
fillets in your model. The number shown above the Rounds icon indicates the
number of fillet chains (as opposed to individual fillets) found.
Note: When
possible, fillets should be removed in chains rather than
individually.
You'll notice the default search value may automatically find more fillets and
rounds than you want. Click the button
on the guide bar and select Find Options.
Change the upper bound for the Radius from 32.5 mm to
5 mm and press Enter.
This will filter the search results so that only fillets and rounds with a
radius of 0 mm to 5 mm are selected.
With the filter applied, the number of round and fillet chains detected drops
to 6.
Remove Rounds and Fillets
Click the Remove All button to remove all fillets and rounds.
You'll notice not all fillets have been removed. Due to construction
history, chains of fillets and rounds are removed in the same order they were
created.
Click the Find button in the guide bar. Notice the number of rounds is
now 3.
Zoom in on the single fillet that appears in the top left corner of the
model.
Note: You can select, deselect, and remove individual rounds or chains of rounds
in the following ways:
Click on a round or fillet to select it.
If there are several contiguous rounds or fillets, double-click one
to select the entire chain. Selecting an adjacent round/fillet will
add to the chain.
Click on a selected round or fillet again to remove it. If it is a
part of a chain, the entire chain will be removed.
Hold down the Ctrl key and left-click to deselect a round or fillet.
Hold down the Ctrl key and double-click to deselect an entire
chain.
Click the Remove All button again.
Now the rounds and fillets are completely removed.
Push/Pull Interior Faces
With the rounds and fillets removed, it is possible to push and pull the
interior faces. Select the Push/Pull tool on the Geometry
ribbon.
Left-click once on the face shown below:
Click and drag the pyramid to position it on the exterior face.
This will redefine the starting point of the push/pull operation.
Type 12 in the microdialog and press
Enter.
Repeat the push/pull procedure for the other interior face, pulling it to
12 mm.
