Pretension
Applying pretension to bolted and screwed connections allows a more complete understanding of the behavior of a structure.
Often, these preloads are of a significant magnitude and can influence design decisions.
Typical examples are clamping structures, such as bearing housings or bicycle handlebars and seat-posts. In engines, cylinder bore distortion can be a critical design requirement highly influenced by the loads generated by the bolt down of the cylinder head.
Figure 1. Enabling and defining pretension in the Property Editor
Figure 2. Results showing automatically generated load case: Subcase 1
Pretension Properties
Following is a list of pretension properties and the types of objects to which they apply (indicated in parentheses).
- Press F3 to open the Property Editor.
                Use Enable (fasteners)
- Select the checkbox to allow entry of a pretension force for fasteners.
                 Use Force (fasteners)
- Enter a magnitude for the pretension force.
