Solid Material Properties
The Solid material type is a parameter used with the BEGIN MATERIAL data block. This material must be used when solving conjugate heat transfer problems.
Solid Steel {
  Density = p
  SpecificHeat = Cp (T)
  XConductivity = K (T)
  YConductivity = K (T)
  ZConductivity = K(T)
  VolumetricHeatSource = Qvol
  CoeffOfThermalExpansion = β
  YoungModulus E
  PoissonRation = ν }
