If the extrusion has a metal insert, that condition is applied using insert parts. Inserts are modeled using BCs
(the interface condition between insert and the polymer).
Use the Show Analysis Results tool to view the results of an analysis in the Analysis Explorer. View and animate results,
add callouts, and compare results from different runs.
View the status of the current run, as well runs for the current model that have not yet been viewed. To see all past
runs, you need to view the run history.
