Tutorial: Run Using Existing Mesh
Submit a run starting with an existing mesh file.
- The mesh file units should be in meters.
- The part names should match the names of the geometry parts in Inspire RTM with 3D suffixed. For example, if the geometry part is spoiler, then the mesh part is spoiler3D.
- The mesh file should contain only the meshed components.
Open the Tutorial Model
Data files are available in the tutorial_models folder in the installation directory in Program Files\Altair\2022\InspireExtrude2022.2\tutorial_models\rtm\tutorial-2\.
The model has three parts: spoiler, support1, and support2.
The Inlet and Vent BCs are already applied.
