Quickly find out how many items are in an entire model, an assembly, or a part. For example, if you select the entire
model, you will see the number of forces, supports, assemblies, parts, loads, etc. If you select a part, you will
see the mass, volume, bounding box, center of gravity, features, etc.
Browse and organize all of the entities in your model.
Find Find entities in the model that contain the search string you enter. The search results are not filtered.
Search and Filter
Search entities and automatically filter the results to only display the entities that contain the search string. You can also filter by entity type.
Show or Hide
Show or hide an entity by clicking its icon in the Model Browser or using the context menu.
Customize the Model Browser
Display properties such as mass, element size, and thickness in columns in the Model Browser.
Show Model, Assembly, or Part Information
Quickly find out how many items are in an entire model, an assembly, or a part. For example, if you select the entire model, you will see the number of forces, supports, assemblies, parts, loads, etc. If you select a part, you will see the mass, volume, bounding box, center of gravity, features, etc.
