Layer Setting
To generate a PCB design file using ODB++ data, it is required to properly load the necessary files for the layers. When the required data is imported, you need to match the data to create the PCB design file.
Unit Setup
- UNIT Selection: Select a unit.
- Decimal Point: Enter the decimal point for the coordinates of part and net generation.
Specify JIG Data
Component Layers
- ADD: Add the line.
- Layer Type: Specify the layer type for Top and Bottom.
- Layer Name: Specify the layer of imported Gerber of ODB++ data to match with the Layer Type.
Layer Stack-up
- Resistivity (Ohm/m): Enter the resistance value of the material.
- Reset: Initialize the Layer Stack-up settings.
- Specify the file that define Layer Stackup: Import the Excel format file of the layer stack up information.
- Add: Add a line.
- Delete: Delete a line.
- Physical Layers: Number of the total physical layers.
- Layer Name: Select the layer stacking order as the actual design physical layer.
- Thickness: Specify the thickness of the physical layer.
- Reduce Pattern Width: Enter the reduced width of the produced route. This input value is reflected in the nominal resistance calculation.
- Add Reduce Pattern Width: Specify the reduced pattern width per a target pattern width. This input value is reflected in the nominal resistance calculation.
- Resistivity: Enter the resistance value per a layer. This input value is reflected in the nominal resistance calculation.
Drill Layers
- Add: Add a line.
- Layer Name: Select the drill layer used in the original design data.
- Connect Top: Enter the start drill layer number.
- Connect Bottom: Enter the end drill layer number.
Board Layers
- Add: Add the line.
- Layer Type: Select the layer type.
- Layer Name: Select the layer name corresponding to the layer type.
- Target Layer: Select a layer to apply the board layer set in the Layer Type.
