Component Position
The Component Position DFE rule checks whether a design follows a component placement guideline.
- Item: Enter item name.
- Comp: Select a target component group.
- In/Out: Select a check area type - inner or outer side from the reference
area set in item ④.
- In: If the component is inside the defined area, it reports as passed.
- Out: If the component is inside the defined area, it reports as failed.
- Area: Select a reference location check region.
- Center/Left/Right/Top/Bottom/LeftTop/LeftBottom/RightTop/RightBottom/Edge
- Area Size (%): Assign a ratio criteria as a percentage of PCB length.
Result
- Check whether there is a target component in the inner or outer region.
- For the user-defined region, change its display into polygon with blue
outlines. The component is highlighted green.
