Create a Flexible Body
Convert one or more rigid bodies to flexible bodies. A flexible part will have flexibility properties that allow it to deform under loads.
- Right-click on a part and select Flexible for Motion to quickly designate a part as flexible. The next time you run a motion analysis, all selected parts will be converted before the analysis.
- Two methods are available for enhancing the behavior of flexible bodies: FlexContact+ and FlexContact+ for Joints. For more information, see Flexible Body Contact.
Click the
satellite icon that appears when you hover
over the FlexBody icon to view the status of conversion runs that are
already in progress or that have not yet been viewed. - See Review Flexible Body Modes and Review Flexible Body Results for more information on how to view the results.
Microdialog Options
Use the options in the microdialog to determine what is included in the flex body analysis.
- Normal Modes
Enter the number of flex body modes to include in the analysis.
- Maximum Frequency
- Enter the maximum frequency cutoff.
- Apply
Make the selected parts flexible.
- Stress
Include stress in the flexible body results.
- Strain
Include strain in the flexible body results.
- Speed/Accuracy
Select between Faster flexible body result types with first-order elements, or More Accurate flexible body result types with second-order elements.
, then select
to convert the selected rigid bodies to flexible bodies.
