After running a simulation in another HyperWorks
        application, you can export a .h3d or .h5 file with animated objects. You can then open the
        file in Inspire Render and use the Animate Objects tool to quickly render a
        looped animation.
        First, run a simulation in another HyperWorks application to export a .h3d or .h5 file. Then open
            the file in Inspire Render.
                In the view controls at the bottom left of the modeling window, click the
                        Animate Object
 icon.
                    Note: The time rate is displayed above the icon (for
                        example,
1.00 in the image below). All objects in the
                        view are animated at that time rate.
                You can do the following:
                                    | To |
                                    Do this |
                                    | Change the loop duration for selected objects |
                                            - On the ribbon, click the
                                                  Analysis tab.
                                            - Click the Motion Loop
                                                  icon.
                                            - In the Control Panel, edit the Loop
                                                  duration.
                                    | Change the time rate for all objects |
                                    Enter the number by which you want to multiply the real
                                        animation speed.
   For example, currently it's at
                                            1.00, which is equal to real
                                        animation speed. Enter 2 to make the
                                        animation 2 times faster or 0.5 to
                                        make it 2 times slower.Note: The time
                                            rate impacts the Loop duration of all objects.
                                            For example, you have 2 animated objects (A and B) with
                                            a Loop duration A = 5 seconds and B = 3 seconds. Then
                                            you change the time rate to 0.5 (half of real speed).
                                            The real duration of the loop will be A = 5/0.5 = 10
                                            seconds and B = 3/0.5 = 6 seconds.
                To end the animation, click the Animate Object
                    icon.
