Create Analysis
Create an analysis for your project.
For more in-depth information about each type of analysis, go to the following topics:
On the Main Menu toolbar, click the icon for the desired type of
analysis.
Figure 1. -
Follow the process for the chosen analysis.
Analysis Type Process
- StructuralFrom the drop-down menu, select one of the following: - Structural linear
- Structural non-linear - In the pop-up window, specify separating contact, material non-linear, or geometric non-linear in the popup window.
- Buckling linear - In the pop-up dialog
select the desired structural analysis to define the buckling
load and number of modes.Note: You can also right-click on an existing structural analysis and select Create linked analysis > Buckling linear, then select the desired number of modes.
- Multi-loadcases
- Sequential - In the pop-up dialog select
the desired structural analysis to define the prestress
state.Note: You can also right-click on an existing structural analysis and select Create linked analysis > Structural sequential.
- Modal- For Modal Analysis, in the popup window, specify the Number of modes to find.
- For Modal Prestressed, in the Modal drop-down menu select
Modal prestressed. In the pop-up
dialog, select the desired structural analysis to define the
prestress state and number of modes.Note: You can also right-click on an existing structural analysis and select Create linked analysis > Modal prestressed, then select the desired number of modes.
- DynamicsIn the drop-down menu, select one of the following: - Transient - Specify Time span.
- Frequency response - Specify the frequency span upper and lower limits.
- Random response - Specify the frequency span upper and lower limits.
- Frequency multi-loadcase
Specify damping using Rayleigh damping coefficients or Modal damping.
- ThermalIn the drop-down menu, select one of the following: - Thermal steady state
- Thermal transient - In the pop-up window, specify the number of modes to extract, time span, and the initial temperature.
- FatigueIn the drop-down menu, select one of the following: - SN Time
- SN Sequential
- EN Time
- EN Sequential
The new analysis appears as a new branch in the Project Tree.
