Pan, Zoom, Orbit, Rotate, and Look Around
Pan, zoom, and orbit in the 2D orthographic views and the 3D perspective view.
| 2D Orthographic Views | 3D Perspective View | |
| Pan | Drag with the right mouse button. Mac track pad: Two finger click + drag. |
Ctrl (Command) + drag with the right mouse button. |
| Zoom centered on the mouse cursor | Use the scroll wheel on the mouse. The center of the zoom is determined by your cursor position. |
| Zoom about the screen center |
Ctrl (Command) + Shift + drag with the right mouse button Mac track pad: Two finger tap + drag. |
Ctrl (Command) + Shift + drag with the right mouse button |
| Orbit around the object | N/A | Drag with the right mouse button. |
| Trackball rotate | Drag with the middle mouse button. | Ctrl (Command) + drag with the middle mouse button. |
| Turntable rotate | Shift + drag with the right mouse button. | |
| Set center of rotation and use trackball to rotate | Shift (+ Command) + drag with the right mouse button. | |
| Look around | Drag with the left and right mouse buttons. |
