Using the Multi-Wall Model (COST 231)
The indoor database is solved using the multi-wall model (COST 231).
The WinProp Getting Started Guide contains step-by-step instructions on how to get started with WinProp.
This example considers the application of analyzing a Wi-Fi router in a building.
Before starting this example, check if the topics discussed in this example are relevant to the intended application and experience level.
Before starting this example, ensure that the system satisfies the minimum requirements.
WallMan tool is used to prepare a geometry database (3D model) that is used as part of a ProMan project. Preparing geometries in WallMan, or even just converting them from other sources in WallMan, is a common step in indoor and urban scenarios.
The ProMan (propagation) tool is designed to predict path loss accurately between transmitter and receiver. The ProMan (network) software offers network planning modules.
Launch ProMan in Microsoft Windows using the Feko Launcher utility (which includes WinProp and newFASANT).
View the main elements and terminology in the ProMan graphical user interface (GUI).
Load the indoor database that was created in WallMan.
For this example, a single antenna site and antenna are defined.
The three main computation methods for indoor databases in ProMan are the 3D ray tracing (SRT) model, dominant path model (DPM), and the multi-wall model (COST 231).
Define the resolution grid for the result matrices and the height at which the prediction results are computed.
Specify the folder for the prediction results to be computed using the multi-wall model (COST 231).
Specify the predictions to be computed.
Select the multi-wall model (COST 231) as the computation method.
Save the new project to file.
Compute the propagation for the antenna to obtain the prediction results.
Display the power prediction results in 2D using the multi-wall model (COST 231).
The indoor database is solved using the 3D ray tracing (SRT) model.
Display the difference between the two sets of prediction results obtained using the multi-wall model (COST 231) and the 3D ray tracing (SRT) model.
In ProMan, the indoor database can be viewed in 3D to validate the physical structure and results.
This example showed how to analyze a Wi-Fi router in a building, to create the 3D model (indoor database) using WallMan and to obtain coverage plots using ProMan.
This example considers the application of analyzing the indoor cell-phone reception, set in an urban environment.
This example considers the application of analyzing base stations in a city, set in an urban environment.
This example considers the application of analyzing base stations on hills near a city, set in a rural or suburban hilly terrain.
This example considers the application of analyzing three base stations, set in a building. The network planning simulation is based on a pre-defined air interface file.
The Altair installation directory contains a collection of examples that shows you WinProp concepts and essentials.
WinProp is a complete suite of tools in the domain of wireless propagation and radio network planning. With applications ranging from satellite to terrestrial, from rural via urban to indoor radio links, WinProp’s innovative wave propagation models combine accuracy with short computation time.
View the typical workflows when working with propagation simulations in specific scenarios, how to add a network planning to a propagation simulation, include a receiver pattern, set up a time-variant scenario, include multiple-input multiple-output (MIMO) at both the base station and the mobile station, connectivity analysis of sensor networks and optimization.
The WallMan component offers a convenient facility to generate and edit vector building databases.
The TuMan tool enables you to generate and modify tunnel scenarios.
Use AMan to generate, edit and analyze a single antenna. Superimpose multiple antennas radiating similar signals to determine the actual antenna pattern while taking into consideration the local environment.
The ProMan component includes wave propagation models for different scenarios and network planning simulators for various air interfaces.
WinProp includes empirical and semi-empirical models (calibration with measurements possible), rigorous 3D ray-tracing models as well as the unique dominant path model (DPM).
In WinProp various air interfaces and applications are pre-defined: broadcasting, cellular, wireless access, WiFi, sensor networks, ICNIRP and EM compliance.
The OptMan component allows the automatic optimization of orientations of antennas in cellular networks to achieve various targets.
The CoMan component allows the simulation of the reliability and connectivity in wireless mesh / sensor networks.
The WinProp utilities consist of the Launcher utility and the Updater.
ON THIS PAGE
ON THIS PAGE
