View new features for PollEx 2022.3.
Discover PollEx functionality with interactive tutorials.
Discover PollEx functionality with comprehensive user guides.
This section contains the user guides for the following tools: Block JIG Generator, Compare GDSII, Gerber to PCB, Make Board Paneling, Metal Mask Manager, Mounting Data Extractor, Mounting Emulator, Router-Machine JIG Generator, Solder Quantity Calculator, Soldering Pallet, Test Point Location Generator, and Underfill.
This section contains the user guides for the following tools: BOM, CAM, Component Arrangement Plan, CP, Golden Sample, Logic, PCB, Redmark+, and Worksheet Planner.
Environment migration is a tool that migrates environment files used in the previous version of PollEx to the latest version.
PollEx BOM is a BOM parsing and formatting tool
Use PollEx CAM to handle any type of Gerber, such as 274D or 274X, convert 274D to 274X type, and compare each revision data.
The Component Arrangement Plan function replaces a paper worksheet with a graphic display report that shows on-board components with their area and marking at first pin.
PollEx Cross Probe (CP) supports two checking types, Same Type Check/Compare and Link and Search.
PollEx Golden Sample generates guide documents automatically.
Use PollEx Logic to import and view schematic sheets, designs, check symbols, nets, and object properties.
PollEx suite is a knowledge-based design-verification toolset for PCB.
Explore the PollEx PCB interface.
The PollEx PCB tool bar contains frequently used menus.
View controls enable you to control the view and display of your model in the modeling window.
Use the File menu to check basic functions, import ECAD files into PollEx PCB, and export working design to 3rd party EDA vendor formats.
Import ASCII files from ECAD vendors.
Read ASCII file, *.PDBA, in PollEx PCB.
Export design to XML file, *.PDBX, in PollEx PCB.
PollEx PCB supports exporting to other EDA vendors’ format.
Save some parts of whole board, after selecting nets and connected components for selected nets.
Using this menu, you can export file to be used in GDSII Format.
Using this menu, you can export Image file as *.jpg or *.bmp.
You can export design data to ODB++ format.
Under the setting menu, there are many settings for defining default value for using PollEx PCB. Use the menus under Setting in main menu.
Use the View menu to control the display more efficiently.
Using Properties menu, you can see and edit properties of objects on board or library link.
Under the Tools menu, there are many useful functions. Almost functions help you to get documents or reports for nets or components.
Refer to each individual user guide for the analysis products in the Solver User Guides Section.
PollEx PCB supports different viewers for reviewing objects on board.
Refer to each individual manual for the manufacturing products.
Redmark is a function to make comments in the design. This function can be used to leave messages or comments to assign tasks.
In Redmark+, it is enabled to get the upgrade features for mark-up tools such as drawing object, text, measurement and reply, history, and so on.
PollEx Technical Cleanliness (TC) is an optional module of the PollEx PCB and a reliability analysis tool set for hazardous areas on a PCB design, using its micro particles.
This section contains the user guides for the following tools: PI, SI, SI Explorer, and Thermal.
This section contains the user guides for the following tools: DFA, DFE, DFE+, DFM, and Logic DFE.
This section contains the PollEx UPE user guide.
Definition for meta character using in making sentence for searching option.
