Cadence - Import from Allegro Design
Import library from existing design file.
View new features for PollEx 2022.3.
Discover PollEx functionality with interactive tutorials.
Discover PollEx functionality with comprehensive user guides.
This section contains the user guides for the following tools: Block JIG Generator, Compare GDSII, Gerber to PCB, Make Board Paneling, Metal Mask Manager, Mounting Data Extractor, Mounting Emulator, Router-Machine JIG Generator, Solder Quantity Calculator, Soldering Pallet, Test Point Location Generator, and Underfill.
This section contains the user guides for the following tools: BOM, CAM, Component Arrangement Plan, CP, Golden Sample, Logic, PCB, Redmark+, and Worksheet Planner.
This section contains the user guides for the following tools: PI, SI, SI Explorer, and Thermal.
This section contains the user guides for the following tools: DFA, DFE, DFE+, DFM, and Logic DFE.
This section contains the PollEx UPE user guide.
PollEx UPE is a unified part library management system.
Create new parts, open existing parts, or import from ECAD library.
Create a new part.
Open an existing part in the part library.
Import part library ASCII files from various ECAD vendors.
Import Zuken Board Designer part library (CDB) ASCII file.
Mentor Graphics has several different ECAD tools, but PollEx UPE can read Board Station and Expedition part library file only.
The Cadence part library interface has two types, one is importing from existing design file and the other is importing from Cadence part library file.
Import from Allegro part library.
Import a PollEx UPF XML file, *.upfx which is extracted from PollEx UPF binary file.
Import data from another part when editing a part library.
Export part library to other ECADs or export part information to other parts or make libraries for various mounting machines.
Control the display.
View and edit properties of a part.
Use various modelers and editors in this menu to make simulation model libraries, general information properites, and configuration tables for logic symbols and footprints automatic generation.
Define the files and folders such as part library folder, general information files and configuration table files. You also can define the initial view configurations and ECAD interface settings.
View PollEx version and access the help.
PollEx UPE supports General, Package, Footprint, and Logic Symbol editors.
Definition for meta character using in making sentence for searching option.
