PollEx
PollEx
2022.3
  1. Home
  2. PollEx User Guides
    Discover PollEx functionality with comprehensive user guides.
  3. Verification User Guides
    This section contains the user guides for the following tools: DFA, DFE, DFE+, DFM, and Logic DFE.
  4. DFE+
    PollEx DFE+ is a fully automated SI analysis tool.
  5. Common Setup for Analysis
  6. Common Setup for Analysis
  • What's New
  • Get Started
  • PollEx Tutorials
  • PollEx User Guides
  • Character String Search Rule
Index
PollEx
2022.3
PollEx
  • What's New
    View new features for PollEx 2022.3.
  • Get Started
  • PollEx Tutorials
    Discover PollEx functionality with interactive tutorials.
    • Manufacture User Guides
      This section contains the user guides for the following tools: Block JIG Generator, Compare GDSII, Gerber to PCB, Make Board Paneling, Metal Mask Manager, Mounting Data Extractor, Mounting Emulator, Router-Machine JIG Generator, Solder Quantity Calculator, Soldering Pallet, Test Point Location Generator, and Underfill.
    • Modeler User Guides
      This section contains the user guides for the following tools: BOM, CAM, Component Arrangement Plan, CP, Golden Sample, Logic, PCB, Redmark+, and Worksheet Planner.
    • Solver User Guides
      This section contains the user guides for the following tools: PI, SI, SI Explorer, and Thermal.
    • Verification User Guides
      • DFA
        PollEx DFA is an assembly status checking toolset for PCB design based on 3D package library.
      • DFE
      • DFE+
        • Common Setup for Analysis
          • Environment Setting
            In this section, PollEx Environment setting methods are explained.
          • Create a New Project
            • Stackup
            • Material Libraries
            • Assign Simulation Model
            • Assign Net Class
            • Assign Net Properties
            • Composite Nets
            • Net Buses/Groups
            • Electrical Analysis Constraints for SI Analysis
        • Input Setup
          Explore DFE+ input setup methods.
        • DFE+ Items
        • DFE+ Environment
          In this section, DFE+ Environment setting methods are explained.
        • Result
      • DFM
        PollEx DFM is a board level manufacturability checking software.
      • Logic DFE
        PollEx Logic DFE is a toolset that checks electrical validity and standardizing of schematic design.
    • UPE User Guides
      This section contains the PollEx UPE user guide.
    Definition for meta character using in making sentence for searching option.
PollEx
PollEx
2022.3
  1. Home
  4. DFE+
  • What's New
  • Get Started
  • PollEx Tutorials
Index
  • Stackup
  • Assign Net Class
  • Composite Nets
  • Net Buses/Groups
