Identifiers
Identifiers are user-defined names that can refer to literals, other identifiers, or functions.
Identifiers must start with a letter (a through z inclusive, upper or lower case). After the first character, letters, numbers, and _’s may be used.
- a
 - A7
 - my_variable
- 8abcd (must begin with a letter)
 - my_invalid-function (must use only letters and _'s)
- function
 - return
 - end (this is a special case and can be used as a function in certain circumstances)
 - for
 - while
 - break
 - if
 - elseif
 - else
 - global
 - otherwise
 - persistent
 - switch
 - case
 - try
 - catch
 - classdef
 - continue
Not all of these keywords are supported in OML, but they are reserved for future use.
