Run in GUI (Interactive and Graphic) Mode
GUI mode provides access to all editorial, execution, and management features of the Integrated Development Environment (IDE).
Run in GUI Mode on Windows
Run Activate from the Windows Start menu or installation directory.
- From the Start menu, select .
- From the directory where Activate is installed on your system, select the executable file: <installation_directory>\Activate.bat.
- From a command prompt, enter:
<installation_directory>\hwx\bin\win64\runhwx.exe -c "Activate" -v Activate2022.3 -ef Act.env -ex ExecMainAct.exe
<installation_directory>\Activate.bat -f
foo.scmRun in GUI Mode on Linux
Run Activate from the Linux terminal.
<installation_directory>/scripts/Activate
-f foo.scm
