Orient the model with respect to the direction of gravity (the z-axis) in order to control the flow of the liquid
as it enters the mold and solidifies.
Define the casting parts, filling system, and gravity direction.
Designate Casting Part
Select the casting parts and define the material, alloy, and temperature.
Designate Filling System
Select the runners through which the molten metal flows to enter the mold cavity.
Set Gravity Direction
Orient the model with respect to the direction of gravity (the z-axis) in order to control the flow of the liquid as it enters the mold and solidifies.
Designate Mold Opening Axis
Select the axis along which the mold will open and designate the demolding angle.
