Add/Edit Riser
If you haven't designed any risers in a CAD tool, you can create and edit virtual risers in Inspire Cast.
Microdialog Options
Define the position, modulus, and diameter of the riser.
| Option | Description | |
| Move |
Click to move the riser. |
| Modulus |
Enter the modulus (volume divided by surface area). |
| Diameter |
Enter the diameter. |
