Resolve Python Compiling Errors
Errors may occur if you compile the Python package from the source code. To install the Python package from the source, perform the following compiler setup.
Windows
Setup Visual Studio compiler in the DOS command prompt.
- If you have other versions of Visual Studio installed, redefine the environment
variable VS100COMNTOOLS.
set VS100COMNTOOLS=%VS140COMNTOOLS%
- Open the Developer Command Prompt for VS 2019.
- Run the VsDevCmd.bat file.Note: VsDevCmd.bat file can be located in:
<Drive>\Program Files\Microsoft Visual Studio\<Version>\<Offering>\Common7\ToolsOR<Drive>\Program Files (x86)\Microsoft Visual Studio\<Version>\<Offering>\Common7\Tools
Linux
- Use the compiler gcc (GCC), version 8.3.1 20190311, and define the environment variable LIBRARY_PATH, in bash shell.
- export LIBRARY_PATH=<INSTALLATION_ROOT>/.altair/common/python/python<version>/linux64/lib
