Particle Body Forces
Using the Interaction pulldown menu and + pick-list, you can build a list (stack) of particle body forces. The top element is applied first, then the next one down and so on. Use the up and down buttons to move the force up and down the list. To remove an item, click the x button. Click the preferences button to configure the selected force.
The following Particle Body Forces are available in EDEM:
